How to chose stall speed?
Old 09-01-2011, 03:03 PM
TPIIROC's Avatar
Default How to chose stall speed?
Combination,
1986 Camaro
5.3
Ls1 heads
Cam 204/218@.050 .551 lift 112LSA
Truck manifolds
T76 turbo
4l80E transmission
Trans brake
3.50 rear gear
28 inch tall tire
Running E85 and looking at about 500-600 wheel hp.
I was kind of leaning towards 3600 stall. But looking for any input.
Old 09-01-2011, 03:15 PM
Restricted User
z99ls1's Avatar
I know converter builders have alot of trouble specing converters for turbo cars... I would say something like a 3200 with your mods. To keep it real tight.
Old 09-01-2011, 08:18 PM
Camarosteve44's Avatar
I would do a 3600, havnt heard anything bad about a yank 3600 ever.
Old 09-01-2011, 08:25 PM
mred's Avatar
4000 get that turbo to spool and letter rip.
but really i would call some of the larger builders and talk with them. you are going to probably get a few different responses.
like mine.....
Old 09-01-2011, 08:37 PM
Circle-D's Avatar
I think 3600+ will be a good range. Make sure you will have no problems spooling it. Getting something custom built for your setup is highly recommended. Turbos are probably the hardest combo to build for. I would also suggest a multi disk, so you can lock up on the big end and load the turbo....
Chris
