Any one running a scavenge pump setup
Old 09-01-2011, 04:14 PM
baezi z06's Avatar
Default Any one running a scavenge pump setup
Hi guys wondering
is any one running a scavenge pump setup whith their nitrous motors
i have LS2404ci built whith a bit loose rings to handle bigger shots better but it pushes bit of oil.
I run Catch can and breathers but i´m thinking if these dry sump scavenge pump are better but who runs them and what does people recomend.
i have AC delete
thanks
Baezi
Old 09-01-2011, 04:46 PM
repo's Avatar
all the "big" guy's around here run a vaccum pump on their engines. They are in the 5.30 range in the 1/8th (TCI Tuff Street)
Old 09-01-2011, 07:09 PM
BLK02WS6's Avatar
I ran a vacuum pump on my 408 for that reason... just be sure to put a vacuum breaker on it and set it to the recommended vacuum so you don't suck the oil out of the bearings at high RPM...
Old 09-02-2011, 03:15 AM
baezi z06's Avatar
Hi
exactly what i'm afraid off that's why i'm calling for some recomended setups.
need some good advice on what works and what doesn't
Baezi
Old 09-09-2011, 02:28 PM
Formula383's Avatar
Check out GZ Motorsports. I just put one of their kits on my motor a few months ago.
Old 09-09-2011, 08:12 PM
6 & 8 Second Club
mrdragster1970's Avatar
I've run a vacuum pump on a standard engine for years to try & do everything possible about oil in the charge.
I don't like to pull more then 15in to keep the pins from going dry!!
Oil and N2O definitely don't mix.
Good luck.
Oh yea, I just bought the good Moroso Tue. because I think my old set up is screwed up.
Old 09-09-2011, 08:13 PM
10 Second Truck Club
67SS509's Avatar
Here's a pic of mine from GZ Motorsports installed a few months ago.
Old 09-13-2011, 06:31 PM
BLK02WS6's Avatar
The GZ motorsports is what I ran... set my vacuum breaker at 13" if I remember right...
Quick Reply: Any one running a scavenge pump setup
