Northwest Members - Can I get this set up to Pass the WA sniff test
the_reaper
09-01-2011, 04:52 PM
So I am in the proccess if throwing a stockish lq4 botton end with a set of ls3 heads and intake into a 93 YJ jeep with a 4l70E trans with a 2700 stall. I am looking at a cam from Texas Speed
Texas Speed Torquer V2 232/234 .595"/.598"
The motor will be a gen III using a 24x reluctor wheel, I dont have the ecm yet but my question is can I get that cam to pass the sniff test in Washington with a good tune. I dont mind having to get a bit creative to get it to pass. THis will be mainly for sand and any unexpecting 5.0's in the area :)
Thanks for the input
tmoney223
09-01-2011, 08:06 PM
Should be able to. There is a guy on here who has heads and a MS3 cam and passed NP.
Nitroused383
09-02-2011, 06:07 AM
You can get damn near anything to pass an ob2 test. That cam will not pass an actual emissions sniffer test though. Not really well matched for a 2700 rpm stall either. I think a 224 cam on a 114 is about as big as you can go to pass exhaust emissions.
the_reaper
09-02-2011, 10:21 AM
ok thank you i am just wondering about my head selection with that small of a cam. as for the stall i can change that.. the issue is the damn sniff test :(
There is no way a 230 something cam will pass a IM240 sniffer test in WA or OR. If its an OBD2 car its a cake walk, I can even write the VIN into a GM PCM, I did just that today in a 97 wrangler with a LQ9 6.0L with a small cam. But that is a OBD2 scan tool test and that is it. If you install a set of CATs and a much smaller cam it will be pretty easy to pass. Besides if you are doing this in a Jeep why so big of a camshaft? Its going to get lousy performance at crawling speeds. Most Jeep dudes go with a pretty small cam, something like an old LPE GT2-3 cam is a very good choice for low speed drivability and low end torque.
the_reaper
09-03-2011, 11:06 AM
well this jeep will never crawl :) i am building it for street queen use and for blasting up the dunes i wanted some power to be able to spin the 15" paddle tires that it will be running while in sand.
Nitroused383
09-03-2011, 03:52 PM
I would give Geoff a call at EPS. He will get you hooked up with exactly what you need. You don't need a big cam to make power, I made 444 rwhp / 414 tq with a 224 cam and unported 243 heads.
the_reaper
09-04-2011, 03:23 PM
Will do and I appreciate all the input, I am new to the ls world but not to the SBC, I have a gen 1 forged 383 with afr heads, Gen 7 and a F1a Procharger that I got to pass with 80lb injectors running a 220/228 @50 cam ;)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
