Too much grinding??
Old 09-01-2011, 07:40 PM
bottlefed01z28's Avatar
Default Too much grinding??
i just got a set of weld prostars 15x4 with a 1.875 back space and im trying not to run a spacer up front so i started grinding the one caliper. it is possible to grind too much? ive been going at it for like 3 hours now and it almost looks like i still have about an 1/8 of an inch still to grind off.
Old 09-02-2011, 01:35 AM
meine96ws6's Avatar
The spacer would have been easier
Old 09-02-2011, 06:09 AM
Yes it would have been easier but if u rear the fine print they always say spacers r not recommend and I'm not the kinda person to do something half *** just cause it's easier
Old 09-02-2011, 09:01 AM
thunderstruck507's Avatar
Grinding the calipers a lot is way worse than a small spacer IMO. Seems like a good way to weaken the already soft aluminum allowing them to spread during braking.
Old 09-03-2011, 01:43 PM
3rdgen92maro's Avatar
Grinding the calipers to fit prostars takes awhile man. I spent a solid 7 hours on my fronts to get them to fit.
Old 09-03-2011, 09:27 PM
69TA's Avatar
how is the caliper even safe after all that metal that you removed from it
