having trouble finding stock ls1 parts
need a few different things for a 98 ls1, need bolts for fuel rail (all 4) i believe they are all the same bolts as the studs used for the coil packs, so if you have those they will work also. need them badly. Also need the vacuum hose from the rear of the intake manifold to the brake booster (including the fitting that plugs into the booster please) if you only have the hose i can make do with something. So the things listed are-
fuel rails bolts (4)
and brake booster vacuum hose with fitting. Please pm me if you have these and a price SHIPPED. Thanks
