vintage air compressor bracket?
looking for pics and measurements of their bracket they sell that mounts the sanden 508 compressor in the stock location of the ls1 f-body on the bottom pass side of the motor. I would like to know if it moves it farther away from the block. here is the link. It gives me some dimension but my motor is apart so I cant measure the factory location. thanks
http://vintageair.com/catalog11/pg62wc.pdf
looking for pics and measurements of their bracket they sell that mounts the sanden 508 compressor in the stock location of the ls1 f-body on the bottom pass side of the motor. I would like to know if it moves it farther away from the block. here is the link thanks
Somewhere on here was a build in an A body, I think it was "pistolpete", he has a blueprint for a mount you could probably use. Similar to the vintage mount, only better, closer to the block and moves the compresser forward to use the main belt. I modified it a bit and used it on mine, works fantastic. Just note, I used a corvette drive system.
Pump as I have it is on the main pulley and the back of the compressor is about 1/4" from my chassis . p m me a mailing adress and I'll send a set os templates , JOHN
