procharger conversion vehicle q's
I am still working on getting my procharged ls6 into my 81 cuttlass. I have a few issues I need help on.
1. The ps pump has been giving me alot of issues. Is the 5/8 hose inlet for the ps pump(i have a C6 pump) pressed in? Can I take it out? Can I press in a 5/8 tube with a 90 degree elbow in it? Does anyone already make this elbowed fitting?
2. For the iat sensor. Do i need a sensor that will thread into my inlet tubing with a bung? will an 88' camaro v8 iat sensor work? will it work with a 99' LS1 pcm? will it work with the factory harness plug?
3. What size couplers do I need to go from 3" tubing to factory MAF and factory throttle boddy?
Thanks in advance for any help.
You can get a iat sensor from a Typhoon/Cyclone from any auto parts store, they work. The maf is 3.5", not 100% sure but I think the throttle body is 4.25" or close to it. I had a hell of a time finding a coupler for it. www.siliconeintakes.com is where I ended up finding mine.
