Polluter cam results
Just got the polluter from tick performance tuned the car is a 2000 slp ss m6 carits has slp lidlid pacesetter long tubes ory pipe with all the emisions deleted it made 439rwhp and 405flbs of torque every dyno is diffrent but the same dyno got 435rwhp out of a 20115.0 mustang with full exhaust and cold air in take and hand held tuner just to give a idea of how it reads
400 RWTQ is not hard to hit with stock heads. I've personally seen 400 RWTQ from a TS 228 cam with a under drive pulley, light flywheel on an M6 SS that I built. That set up put out over 400 RWHP and 400 RWTQ. Not much over but over all the same. Of course headers and bolt on's. All these engines are different some will some won't. Under drive pulley in combination with that Texas Drivetrain Performance light weight flywheel they have ( Findanza I believe ) was the key there. One guy said these numbers was suspect a few post back and I here to tell you 400 RWTQ can be had with stock heads. All day long.
