wiring woos
wiring woos
I was running spray for about a month in 2010, I took it off my car with nothing wrong. I had my motor built in early 2011, and wanted more power, so back on the kit went. I wired everything and the kit would not fire. So I rewired everything. I suspected my tick window switch might be the culprit, so i sent it to the guys at nitrous outlet. I got the switch back 6 weeks later to find out that one channel did not work.
No worry's, I only planed to run a single stage. I wire it back in, and still have the same problem. I then rewired the whole kit a third time today. 4 hours later I made progress.
The kit does not work, but the relay and soloniod both click when it should be firing. do you guys have any idea what might be wrong?
for wiring purposes, this is what I used
https://ls1tech.com/forums/6968779-post85.html
