footbrake RPM with a Yank SS3600*******
Old 09-04-2011, 10:01 AM
ejbta's Avatar
Default footbrake RPM with a Yank SS3600*******
What can you footbrake rpm with your ss3600 before your tires break loose and did you have to tune your trans. after you installed your converter?
Old 09-04-2011, 11:53 AM
pat-ls101's Avatar
I can footbrake mine to around 3000 rpm before tires break loose. I also have 2.73 gears...
Old 09-04-2011, 02:14 PM
gyrene2003's Avatar
Yeah, maybe I can manage 2500, but that is with the 3.90s-4.10s
Old 09-04-2011, 02:15 PM
gyrene2003's Avatar
Oh, and I have an SS4000
Old 09-06-2011, 06:05 PM
blk/slvr02ss's Avatar
I foot Brake mine @ 1000 rpms and best 60ft on Nitto 555r's 1.61 60ft and that was on my 2002 Camaro SS.
Old 09-06-2011, 10:25 PM
Duffster's Avatar
Mines a TCI Super Streetfighter and I make it to about 2500-2600 before the 4.30 rear starts turning... Was just wondering this same thing myself. Thanks for posting the question
Old 09-07-2011, 12:22 PM
ejbta's Avatar
I am debating on a ss3600 or a ss4000 and will most likely go with the ss4000, but did anybody have to tune their car after the converter?
Old 09-07-2011, 01:07 PM
1badWS6's Avatar
You will need a tune after a tc install.
Old 09-07-2011, 02:39 PM
01ssreda4's Avatar
Agreed, at the very minimum a mail order tune.
Old 09-07-2011, 10:46 PM
pat-ls101's Avatar
A tune is a must. I have the Diablo software for my computer. There's Wayy better out there but it works pretty good for what I have...
Old 09-07-2011, 11:38 PM
Restricted User
z99ls1's Avatar
I just drove a car today with a yank 3600 stall with heads/cam. It foot braked to about 2700 before the tires broke loose. It wasn't on very good tires though...
Old 09-08-2011, 02:28 AM
mikat1's Avatar
You don't NEED a tune.
Old 09-08-2011, 02:42 AM
02sleeperz28's Avatar
Agreed. All cars are not the same, some react differently than others once a TC is installed. I personally didn't need a tune once my TC was installed when I had a stock 4l60e, all I needed was a trans cooler. Surely a base tune wouldn't hurt anything for those of you who are **** about having a tune.
Old 09-11-2011, 09:24 PM
ejbta's Avatar
Are you guys taLking about the tuNe on your engine or retuning your trans?
Old 09-11-2011, 09:30 PM
Stippy17's Avatar
I can footbrake to 3k before the tires want to turn at the track. Ive had my best 60fts this way, but many people get their best 60fts going off of idle..
Old 09-12-2011, 02:33 AM
Restricted User
z99ls1's Avatar
What are your guyses shift extension with the yank ss3600 converter? The I drove the other day dropped to 5k exactly and it shifted at 6500 rpm. I think my shift extension would be just as high if I was shifting at 6500 rpm
Old 09-12-2011, 03:25 PM
soundengineer's Avatar
for what its worth...
Yank PY3600... built as a 5000 stall
Footbrake to 2500/2700 ish before my brakes wont hold it any more and I start to roll..
Shift at 6900... RPM Drops about 1200 rpm between shifts on my 2-3 which is my biggest gear split..everything else is right at 1000rpm for me.
Driving a TCI 6x
Old 09-12-2011, 11:42 PM
Fbodyjunkie06's Avatar
Just to let some of you guys that are having trouble pushing through know, the higher (numerically) your rear gear is, the sooner you will push through your brakes due to higher gear reduction making more torque at the tires.
Old 09-13-2011, 12:54 AM
01ssreda4's Avatar
Agreed, foot braking has many factors effecting it.
Old 09-13-2011, 06:28 AM
Duffster's Avatar
Having not thought of that, and if I understand correctly, were I to change from a 4.30:1 rear ratio to say a 3.73:1, I might make 3000 or so rpm before my rear starts moving on brakes? Thanks for bringing this up.
Quick Reply: footbrake RPM with a Yank SS3600*******
