Help with y pipe
Get some poly motor mounts and see if that fixes it. This is a common problem and motor mounts usually fixes it. Some headers also bank on the K-member so make sure there is clearance from header to K-member (generally drivers side).
might just need to do some die grinding on the k member if you have the clearance to do so,i installed poly mount on mine and they still hit on passenger side.
but that was an easy fix as well.
GL
Ed
GL
Ed
