Pontiac GTO 2004-2006 The Modern Goat
04 gto headers
Old 09-04-2011, 09:57 PM
mdrcm7's Avatar
Default 04 gto headers
I am looking for headers for my 04 gto. I have straight pipes ran right now still with the cats intact and I want the headers to support a future procharger. Any suggestions on brand, size, etc...
Old 09-05-2011, 12:54 AM
batboy's Avatar
Hard to beat Kooks if you want high quality stainless steel. If you want to cheap out then look at Pacesetters. Maryland Speed has good prices.
Old 09-05-2011, 07:00 AM
Stormed_Norm's Avatar
I bought the engine from this guy. He still has the headers from the car:linky:
https://ls1tech.com/forums/parts-cla...cam-stall.html
Pretty decent guy to deal with.
Old 09-05-2011, 09:15 AM
motor_moose's Avatar
Kooks for my vote. Just last winter I was trying to decide to go with Kooks or save my money and buy pacesetters. And I talk into buying Kooks and I don't regret it one bit.
Old 09-05-2011, 08:20 PM
mdrcm7's Avatar
What about size? 1 7/8", 1 3/4" ....?
Old 09-06-2011, 05:44 AM
Rob
Rob's Avatar
Can't really go wrong with any of the high dollar stainless headers out there. I have Dynatech's and love them. If you're looking to save money, get them used when they pop up in the classifieds.
Old 09-06-2011, 05:51 PM
99SilverC5A4's Avatar
i have a set Dynatech with a jet hot 2000 coating in black, they are for sale if you want to get a used set. i loved them i just had to upgrade to a set of custom 2" primary headers for my new 454 build. send me a pm if you want.
Old 09-06-2011, 06:48 PM
batboy's Avatar
Not really much difference unless you are building a really high HP motor. The 1-3/4" fits better and probably makes more torque on modestly modded motors.
EDIT: I originally said 1-7/8", but meant 1-3/4" (I changed it in the post). That said, I have 1-7/8" Kooks and love 'em. But, I'm putting down about 575 hp with a 150 shot of giggle gas. A bolt-on only car would be perfectly fine with 1-3/4" headers.
Old 09-07-2011, 10:16 AM
Larry @ AMS's Avatar
I have Kooks 1 7/8 on my 04 which is just a bolt-on car.
you can't go wrong with any of the below headers
Dynatech
Kooks
ARH
Old 09-22-2011, 06:53 PM
Joeyelbows's Avatar
Its like the saying goes " you get what you pay for". Now i know people will come on here and say pacesetters arent that bad but if i were you i'd go with kooks, arh, dynatech. As for size go 1 3/4 especially since you wanna procharge.
Old 09-23-2011, 09:25 AM
SirMarco's Avatar
I have the Jet Coated Pacesettter w/Jet Coated catless mids. I do not drive the car in the winter though either. Anyways I have no issues with mine and had a huge gain in hp with them. Also with mine, I'm not a baller so I went with what I could afford at the time.
Old 09-23-2011, 10:12 AM
TXB4Z's Avatar
I bought my car with Pacesetters and they work but I hate the slip fit connection between the header and mid pipe.
Old 09-24-2011, 12:21 PM
Joeyelbows's Avatar
Did pacesetter fix the issue with the pipe hitting the steering linkage?
Old 09-26-2011, 07:00 PM
hempkat94z's Avatar
I have a set of Pacesetters for sale on this forum!!! The amount of money you can save over buying Kooks you can buy a cam, springs and 243 heads!!! JMO!!!
https://ls1tech.com/forums/pontiac-g...armorcoat.html
Old 09-27-2011, 08:45 PM
massillongoat's Avatar
I have a set of pacesetters used for a year...up graded there just sitting around 1 3/4
Old 09-29-2011, 07:36 PM
quick346's Avatar
the pacesetters will make just as much hp as the high dollar 1 3/4 kooks but if it is worth the extra 6-700 bucks to put it in the sig go big. but the steel ones will only last 4-5 years witch is way longer than i ever keep a car .but the exhauste could give a **** wether its flowing through a $1000 set of stainless or a $350 set of cheap ones as long as the pipe size is the same.
Old 09-29-2011, 07:45 PM
quick346's Avatar
also 1 7/8 headers on a ls1 is way overkill for a ls1. 1 3/4 is fine for all the 6-7k shift points . i actually have a dyno graph through pace setters pulling to 7200 rpm.it is low but it is through a loose *** converter and a 9" and the car runs 10.90's n/a. it was my gto i sold it but the guy that bought it put it on a portable dyno chassis at ls fest. but this is through pacesetters and 3 " flow masters i did have to grind the end off 1 or 2 of the fender reinforcemeant bolts but that was it.2 minutes with a grinder to save 6-700 bucks .thats money that can be spent on better things
Old 09-04-2013, 01:57 PM
Matias55's Avatar
You still have those Headers for sale??
Quick Reply: 04 gto headers
