General Maintenance & Repairs - rattleing/bad bearing noise... waterpump?
swavely
09-04-2011, 10:02 PM
my 1998 camaro is making this noise when it starts up you hear the noise when the engine is cold but when the engine warms up you cant hear it no more it sounds like a bad bearing on a pulley or something but i think its the water pump but not sure temp gauge is working fine no over heating there was not very much play on the water pump pulley at all hard to explain the sound but it still runs and drives perfectley fine. it also kinda sounds like a rattling sound but its really hard to explain please watch and let me know what you think thanks!
watch video here...
http://www.youtube.com/watch?v=S0aIDfhblBk
swavely
09-05-2011, 07:50 AM
watch video here...
come on guys i need to figure out what this is....
pewter2002
09-05-2011, 08:56 AM
Noisy AIR pump. It shuts off once the coolant reaches a predetermined temp and wont come on until it is cold again.
swavely
09-05-2011, 12:24 PM
are you 100% sure because i cant take any risks of breaking down on the highway getting stuck even thoguht i always have my cell phone.... also i just noticed might be because its getting colder or something but i dont think this is the case my car when starts idles around 1500 rpms but if i shift into like 1st or drive or something it will drop to like 1200 rpms but in N or Park stays at 1500 rpms but i think once i have it started a little while it stays down at 1000 rpms what is the normal idle for a 1998 camaro thats a v6 and automatic?
swavely
09-05-2011, 12:34 PM
hey this is a v6 does my car even have one???
AlamoTA
09-05-2011, 12:46 PM
I had that same sound upon start -up and it went away after starting to drive. This went on for about a week. Turned out to be my compressor clutch. I'd suggest taking off the belts and spinning all pulleys. You'll find it pretty quick. Good Luck!
swavely
09-05-2011, 03:25 PM
to remove the serpinetine belt all i gottas do is push down on the tensioner and it should come right off right? if it is the compresser then what? cause that can be expensive. i think
AlamoTA
09-06-2011, 04:52 PM
Correct; push down on the tensioner and slide the belt off. Make sure you have the schematic of the routing so you can reinstall. Once off, just spin/rotate all your pulleys. If one is bad, you'll see wobbling, feel/hear grinding. I'd look for metal shavings around the shaft as well. If it's the compressor clutch, you can replace just that part for about $100, depending on where you buy it.
swavely
09-07-2011, 02:08 PM
i took the belt completley off turn each pulley no wobbly pulleys or noises know what!?
