Need help identifying these rockers and springs *LS newbie*
The rockers are Harland Sharp, but how would I know if they are adjustable or not, and how would I know what specs they are? 1.7? 1.8?
Also, can anyone identify the springs?
Thanks for your help!
The springs appear to be LS6 yellow stock springs . As far as the rockers , You may need to remove 1 and locate the part # to know what exactly they are . As far as the rockers being adjustable , it's not likely as the LS engines use non-adjustable valve trains with the exception that You adjust for cam changes by way of different length p-rods in .025" increments .
