Pontiac G8 2008-2010 - Can I use the cadi CTS-V calipers on my 09 gt?
LSX-PWR
09-05-2011, 06:22 AM
I was wondering if I could put those calipers on the G8. I know we can use the new Camaro's but I rather go with CTS-V.
Sneakyws6
09-05-2011, 10:06 AM
Check over on the G8 forum to be sure, I think the fronts will fit with no issues other than maybe having to change out the mounting bolt and drilling the spindle to 14mm. The rears will need a custom mounting bracket, a custom e-brake shoe and the camaro rear rotors to work correctly.
blakss
09-05-2011, 11:55 PM
cts v calipers are direct bolt on for the fronts using camaro rotors. if you run camaro calipers though you need to drill out the spindle. as for the rear you need a special bracket and custom brake shoe to keep the ebrake .for more info you can try grrr8.net or g8board.com
Thebeast916
09-06-2011, 04:13 PM
if u r referring to the new ctsv 6 piston brakes. yes they will bolt. just need different wheels to clear the brakes
WhiteDeathLS1
09-06-2011, 06:47 PM
I have the 6 piston set up for my GXP. They will not clear the GT OEM 19" wheels, however. They're a super tight fit against my 505As
