VIDEO: Hate my Exhaust
Old 09-05-2011, 12:00 PM
danbrazda's Avatar
Default VIDEO: Hate my Exhaust
I've been told the "popping" sound my exhaust makes is normal. Please check out the following 2 minute video and let me know if you agree. If you don't want to watch the whole thing skip ahead to the sequence 50 seconds in which is the first time it happens:
http://www.youtube.com/watch?v=zw1Qsg52hc4
Old 09-05-2011, 12:23 PM
SippiSpeedhawk's Avatar
Ya, that's normal. My old TA did that with just an SLP loudmouth exhaust.
Old 09-05-2011, 12:30 PM
BStowers023's Avatar
http://texas-speed.com/p-379-magnafl...ck-system.aspx
Affordable catback that sounds really good IMO, have it on my car and love it.
Old 09-05-2011, 12:45 PM
99Bluz28's Avatar
Doesn't sound like anything out of the ordinary.
Old 09-05-2011, 12:54 PM
99Z28camaroman's Avatar
Sounds fine to me!
Old 09-05-2011, 01:03 PM
egott_91's Avatar
Nothing sounds unusual to me either...
Old 09-05-2011, 01:17 PM
ULTIMATEORANGESS's Avatar
Smile
seems fine.
Old 09-05-2011, 01:19 PM
99 WS-sick's Avatar
thats wat real cars sound like lol not baaaaaa....baaaa hahaha
Old 09-05-2011, 01:45 PM
BigBirdLS1's Avatar
It sounds normal to me also. I could be wrong but it seems to do it when you go WOT and suddenly let off the gas. When you did a real good pull to redline through 2 gears it was barely noticeable but when you shifted at 4k and then a quick 2nd gear pull to redline it was pretty loud. You might try adjusting the fuel trims to keep some unburnt fuel out of the exhaust. But the easiest fix is to add catalytic converters to your exhaust....but who wants to do that.
Old 09-05-2011, 03:15 PM
JD_AMG's Avatar
Are you talking about the rasp in between shifts?
This is normal on a car with an ORY without a good Y-merge.
You could either weld in a better Y-merge pipe(search in GENIII external section), or get cats and most of that rasp will be gone.
Old 09-05-2011, 03:40 PM
danbrazda's Avatar
Thanks guys. I was referring to the popping not the rasp. It still did it when I had my hi-flo cats on but based on the responses I'm guessing I have a crappy Y-merge. Both the cats and the straight pipes are held in by V-Band clamps for easy interchangeability. Should I just have the straight pipes welded in or is there a more secure interchangeable Y-merge solution out there?
Old 09-05-2011, 04:00 PM
sleepinghawk's Avatar
Your car sounds good! The popping is found on alot of our cars. Mine when stock it didn't do it. Soon as I put the LM1 it did it alot more than yours. Then I put the ARH with their high flow cats and it's there and I have no problems with it. I thought like you once, about welding the pipes and now I'm glad I didn't. I have the band clamps and they work good. Every year before the start of the summer I just check them all and look for the black exhaust leak and
Old 09-05-2011, 04:19 PM
danbrazda's Avatar
I'm already learning to love it. Thanks again all!
Old 09-05-2011, 05:02 PM
bestlude's Avatar
sounds badass!
Old 09-05-2011, 05:18 PM
why87's Avatar
sounds fine to me. my welded in muffler pops like that occasionally.
Old 09-05-2011, 06:08 PM
Latch's Avatar
That car sounds great, dunno what the complaint is...
Old 09-05-2011, 06:12 PM
thegerberbaby's Avatar
I think it sounds great!
Old 09-05-2011, 06:21 PM
GWagner's Avatar
Im jealous. Sounds great. I need a car.
Old 09-05-2011, 10:48 PM
thegodfather899's Avatar
i agree with the rest...sounds good
Old 09-06-2011, 01:29 PM
thunderstruck507's Avatar
That is one of the best sounding y pipe systems I've heard. A better Y to cut down the rasp and it would be really awesome
