gains from a SSF 3500?
just curious what kind of gains from a car doing 8.6 in the 1/8th can be expected after just adding a tci ssf 3500. Im going to track tomorrow and am just a little curious .
More info please. What mods do you have prior to the SSF3500? What rear tires are you runnin? That is a hard hitting converter so traction will be a huge issue if your gonna try and run on street tires. But an average gain for a bolt-on car with that verter is .5 or .6 in the 1/4 mile. Not sure how that translates to the 1/8 mile gains but you'll definately want to run at least Drag Radials (heat them up real good first) so you make the most of your TC investment.
Good Luck
Good Luck
I gained a 0.6 in the quarter just after a few tries on MT ET's. Also have BMR LCA's and sway/T-Arm poly bushings.
On the street, forget it I light them up on anything below 50mph.
