best throttle body mass air combintion for ls6 intake?
I have a 98 z a4. Current mods are SLP lid, Tsp long tubes and true duals, ls6 intake, 160 thermostat and 3.73 gear. What would be my best option for a throttle body and mass air with the ls6 intake? Plan on having the car dyno tuned after the mass air and throttle body upgrades and wanted some estimated power #s with the listed mods.
Your 98s stock TB,MAF,fuel injectors are good to around 450rwhp. At your power level its a waste of time. I believe they make an 80mm TB that will fit but thats about all.
Moderator
Take the low budget advice. Descreen MAF, port TB, and call it
good. You don't need any more until you have the heads & cam
& exhaust to draw it down.
That's a "no" to SLP MAF unless you like making your tuner guess
about ****. Sound like fun? Right.
im also a 98 a4 car n imo best mod go yank ss4000 converter and for tb n mass air i use a stock descreened mass air n ported stock tb to 78mm and im putting down with heads and cam 438/403 to the tires n pleased ya theres more to be made but will work on ur setup just fine
If you really want to run a larger MAF then just get one for a z06 vette. I picked mine up used for 90 and then you will need a wiring adapter I believe from fast toys which is 20 I believe. If you really want to be fast build from the rear forward, not the engine back to the rear
