11 Second Club - 11 sec cam only pass!
MNBlade
09-06-2011, 10:15 PM
Got a new personal best over the weekend. Finally in the 11's and get the 11 second tag.
R/T .006
60' 1.72
330' 4.89
1/8 7.58
mph 91.16
1000' 9.91
1/4 11.86
MPH 115.3
Kinda hard to see the photo.
darrensls1
09-07-2011, 02:54 AM
Congrats! Hitting that first 11 second slip is an awesome feeling. What cam and intake are you running?
blk/slvr02ss
09-07-2011, 07:22 AM
Great Time now get your 60FT time down in the low 1.6's high 1.5's for some mid to low 11's !!!!!
bjamick
09-07-2011, 07:33 AM
Damn autos, congrats on the pass.
jebuzws6
09-07-2011, 11:45 AM
what was the DA?
MNBlade
09-07-2011, 07:15 PM
Cam is a comp cam 234 236 with .598 and .545 at a 112 lsa. Intake is a Fast 90/90 set up.
DA looks to be about 2400.
Thanks guys, Pretty much my best pass.
darrensls1
09-07-2011, 08:36 PM
Nice! Just need a better 60' and you'll get mid 11's all day long. What tires were you running? I got 1.5x 60's with mickey thompson street radials on my stock rims and no suspension mods.
MNBlade
09-07-2011, 09:09 PM
Thanks. Ya I was hoping for a better 60' but that was the best I could do, I might send my converter in and have it restalled a bit higher. I was using mickey tompson drag radials on stock rims, but with some suspension mods like lca's and panhard bar.
I was thinking of doing the restall, getting some 15x10 wheels with some 26" MT ET streets, and also get efi live so I can tune it myselft at the track. Probably get some pretty good numbers then.
darrensls1
09-07-2011, 10:03 PM
Did you feel any spin or were you dead hooking? I was hitting 1.6x 60's with a TCI 3500 converter so I cant believe your setup wouldn't at least be in the low 1.6's with full traction. I would run 20 psi in my MT's and do a 5 second burnout to get the best results.
MNBlade
09-07-2011, 10:15 PM
I didnt feel any wheel spin on this pass. I was expecting a lower 60' but even after getting my launch and everything feeling the best, this was the best I could do. I warmed the MT's up really well, probably 5-7 seconds (to warm them up and for a little show as well, they liked that). I ran them at 15 psi.
Would gears make a difference in 60'? Im running 3.89's.
darrensls1
09-07-2011, 10:21 PM
15psi is a little low. Might want to bring that up to 18-20. You're gears are perfect for your setup IMO. Im thinking your problem is in the converter. I would get it refreshed into a ss4000 :D
MNBlade
09-08-2011, 05:26 PM
Ill try that next time I get out there, which will probably be next spring sadly. I think its the converter as well. Ill probably get it restalled and have some good comparison numbers.
darrensls1
09-08-2011, 06:46 PM
I hear you. I would definately up the stall to at least 4000 with your setup. With your cam and gears the bigger stall will not only get you out of the hole quicker but will keep you in your powerband better with the higher shift extension. I wouldn't be surprised if you picked up a mph in trap speed as well as lowing your 60'.
Good luck!
speedtigger
09-08-2011, 10:11 PM
R/T .006
60' 1.72
330' 4.89
1/8 7.58
mph 91.16
1000' 9.91
1/4 11.86
MPH 115.3
What RPM are you shifting at?
Zmg00camaross
09-08-2011, 10:27 PM
I think the reaction time is the best part. Guess your footbraking it. Killer RT fo sho.
MNBlade
09-09-2011, 06:13 PM
Good luck!
Good point.
Thanks.
6600 RPM
Ya footbraking it. I was shocked when I saw it. I also had a .005 the pass before that so I guess I was doing something right, cant say I was doing it right when I had the .453 light though. lol
Mac 2002 SS
09-11-2011, 06:36 AM
Congrats !! :)
1Bad97WS-6
09-13-2011, 10:31 AM
Congrats man..
z99ls1
09-13-2011, 01:31 PM
Going by ur 1/8 mile it looks like your cam has you loosing some low end with that converter. I bet you would gain about .5 with a 4k stall. Good time either way though!
speedtigger
09-13-2011, 01:59 PM
I think your estimation is extremely optimistic. He already has a 3600 converter according to his signature. 7.50s at 91 is just about right actually. He might pick up a tenth or so.
z99ls1
09-13-2011, 11:01 PM
Not even close. A tenth? I gurantee he would gain 3 tenths easy changing to a 4k stall. That is a pretty damn big cam. He would pick up a tenth easy just from the better 60ft with the 4k stall. The stall is just a little bit small for that cam and a 4k would help out alot!
thunderstruck507
09-14-2011, 10:06 AM
What rear gears are you running?
MNBlade
09-14-2011, 10:00 PM
Yukon 3.89
dee99gt
09-15-2011, 07:52 PM
Nice job!! I can't wait to hit an 11sec pass.
createnit
09-15-2011, 08:03 PM
very nice.
MNBlade
09-15-2011, 10:12 PM
Thanks, Its almost a different feeling when you get there.
very nice.
Thanks
z99ls1
09-15-2011, 11:35 PM
Thanks
Is it really? Wonderd if it would be. I remember by 12.9 pass felt good and now im hungry for 11's lol. I can't wait! Im installing some parts to get me there as I type lol
darrensls1
09-16-2011, 07:47 AM
I agree. It's clear the 3600 stall isn't performing the way it should off the line. 4K stall at this point should at least net a .3 drop in ET and probably gain 1 mph in trap.
01ssreda4
09-18-2011, 12:38 AM
15 psi is perfectly fine with MTs.
LS1TA_956
09-18-2011, 12:42 AM
Nice pass congratz
