Motovative
09-07-2011, 09:46 AM
Limited Time introductory sale pricing :
Camaro SS 2010 Emissions Legal System - 6,795$
Camaro SS 2010 Tuner System (no injectors or handheld tuner) - 5,889$
http://www.turboneticsinc.com/sites/default/files/turbochargers/kit_layout_camaro.JPG?1287526897
http://www.motorator.com/uploads/blog_images/0000/2070/Turbonetics_2010_Camaro_Turbo_System_4.jpg
http://www.motorator.com/uploads/blog_images/0000/2069/Turbonetics_2010_Camaro_Turbo_System_3.jpg
http://www.turboneticsinc.com/sites/default/files/54966_445442386021_48666676021_5860451_5491650_o.j pg?1288049891
Turbonetics’ complete, bolt on single turbo kit takes your 2010 Camaro SS from 426 Crankshaft HP to approximately 614HP (578lb/ft) at just under 8psi of boost. The installation can be completed in a day with normal mechanics tools. No cutting or fabrication is required - this kit comes with everything needed to go from stock to muscle car.
The Turbonetics turbo kit runs cooler and at lower boost pressures than comparable supercharger kits, ensuring years of dependable performance.
All system components mount to existing factory locations and maintain all original equipment, including factory air conditioning. With Turbonetics Turbo Systems you no longer have to worry about having your vehicle out of operation for 4-6 weeks in order to get a custom turbo kit fabricated. Our kits can easily be installed in less than a day. All turbo systems are backed by our legendary no fault no hassle one year warranty.
Main components:
· Turbonetics T76 Ceramic Ball Bearing Turbocharger
· Massive Spearco front mount intercooler with a 4.5x26x11” core
· 2 Turbonetics Evolution 35mm wastegates
· Turbonetics Duo 35 by-pass valve
· T304 stainless steel TIG welded exhaust plumbing
· Aluminum intercooler and air intake plumbing
· 8 x 630cc/min fuel injectors
· 8 x NGK TR6 spark plugs
· Diablo hand held programmer with CARB legal tune (CARB approval pending)
· Coolant/window wash fluid reservoirs
· Hardware kit (fasteners, gaskets, clamps, instructions, EO label, etc.)
Main components:
