408 build need some sponsors to purchase from
Putting together a 408 for 91mm turbo. Im going to need a 6.0L block and rotating assembly. What components should I get for rotating assembly. I posted this in Forced induction also but no replies there...
LS1Tech Premium Sponsor
http://www.texas-speed.com/t-Enginebuildinfo.aspx
We can definitely handle your boost build!
The individual components will somewhat depend on the power level you are shooting/planning for, which heads will be going on top, etc. If you can post some more info here or shoot us a line we can put a quote together for you!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
