Cadillac CTS-V - Getting a lot of noise from the front suspension after installing Eibach and mm
dr.duct_mossburg
09-07-2011, 07:16 PM
Installed my eibach springs along with my MM spacers tonight. I did the fronts yesterday and the backs. After doing the back the front right is very squeeky as the front end moves up and down.
Any thoughts??
The whole front is a little creaky but im assuming this could be due to the end links being stock?
wes8398
09-07-2011, 11:27 PM
I'm not sure how the rear would have much to do with the front being squeaky. Did you trim your bump stops?
BudRacing
09-08-2011, 06:52 AM
I've been getting some squeaks from mine too. I think I have a broken endlink though as I've been getting some clunking too. I need to check it out.
punishmentcycle
09-08-2011, 09:44 AM
take a look at at the sway bar bushings.. they suck and cause alot of noise.
demang
09-08-2011, 09:46 AM
did you remove the plastic on the last coil?
