Shaking wont go away again....
Old 09-07-2011, 07:22 PM
ritchie1791's Avatar
Default Shaking wont go away again....
So I got my ball joints, tire rods (inner and outer), shocks (KYB), and rebalanced my wheels and tires, and got an alignment done and my car is still shaking....who can figure out what the problem could be on my car....I have torque thrust II wheels and Maxx v1 tires have 30psi in them. Help please!
Also I dont have any bent wheels and my steering rack is all good and fine
Old 09-07-2011, 07:27 PM
Hashish's Avatar
Bent axle shaft?
Old 09-07-2011, 11:44 PM
its the steering wheel shaking and its not bouncy its just shaking hardcore and I checked the axles
Old 09-08-2011, 06:25 AM
whytryz28's Avatar
Hubs? Warped rotors? Does the shaking get harder with RPM increase?
Old 09-08-2011, 07:24 AM
leadfoot4's Avatar
Can you describe the symptoms a little better? Is is occurring at a specific speed? When accelerating or braking, or at a steady speed? If it shakes at one speed, can you "drive out of it"? Does it happen when driving straight, or when cornering? Any "growling" noises from the front wheels when they're turning?
Old 09-08-2011, 07:22 PM
rabbit320's Avatar
wheel bearings?
Old 09-08-2011, 09:57 PM
it gets worse as you go faster! no noises that I heard of at all just normal road. it shakes while going at around 50mph and up! and when I break it doesn't shake lol weird right
Old 09-09-2011, 08:20 AM
00zrocket's Avatar
MY car does the same thing, if driving in the city at normal conditions the car brakes fine... as soon as i get on the car and reach speeds above 50 and brake .. its doesnt seem safe. i have had a new steering rack put in, alignment, new tires, new brake ?.. something has to be bent on my car and yours ! HELP US !!!
Old 09-09-2011, 08:26 AM
elmarro's Avatar
I just found out what was my problem !! Had it shaking like that for a long time u was going 2 buy a new rearend but last week my cousin wanted 2 try out my wheels,so we exchanged them for the weekend !!! My car smooth as can be my cousins car shaking like a ****!!! Lol do try changing out wheels you never no...
Old 09-09-2011, 09:30 AM
So my Torque Thrust II wheels could be the problem? I heard they would inprove the ride because of the wider sidewalls.....damn that really is not good....
Old 09-09-2011, 09:37 AM
elmarro's Avatar
Bad wheels or tires, just try it with other wheels then you can go from there!! But it happened 2 me that was with new tires!!
Old 09-09-2011, 01:19 PM
leadfoot4's Avatar
It could be the wheels OR the tires. You need to go to a competent shop and have them inspect your wheels/tires. Could be a broken belt in a tire....how old are they?
Old 09-09-2011, 01:45 PM
DopeFedZ's Avatar
If you have a stock set of wheels or another good set of wheels try swapping them and see what happens.
Old 09-09-2011, 05:11 PM
dannyo210's Avatar
Possible the belts in one of the tires could be bad. I've had that problem before
Old 09-09-2011, 06:33 PM
9WhiteCamaro9's Avatar
I would suggest this before you sink money into stuff that doesn't need to replaced unless you want to. I mean it could be something as simple as bad wheels or tires.
