Aussie HJ Kingswood single turbo lsx376
Old 09-07-2011, 08:16 PM
pills85's Avatar
Default Aussie HJ Kingswood single turbo lsx376
Another Australian ute thread
I bought my Kingswood ute about 3 years ago, when it was running a basic Holden stroker setup. Since then it's been through a few changes.
Model: 1975 HJ ute
Colour: Mercedes Pastel Blue
Body Mods: WB Statesman Deville front, doors and bumpers, rear bumper shortened, all bolt holes removed, bare metal respray, tonneau hooks removed, chrome grille, WB taillights
Engine Type: LS1 from a Holden VY SS
Engine Mods: comp cam, comp valvetrain, Canton sheetmetal sump, remote oil filter, mafless tune, alloy Aussie Desert Coolers Radiator, twin fans etc, colder thermostat, corvette fuel reg/filter, Bosch 044
Power: 270rwkw/360rwhp
Intake: Yellaterra mafless intake pipe, ported throttlebody
Exhaust: CAE 1 3/4" tri y extractors, twin 3 inch exhaust, varex muffler
Gearbox: Built TH400, full manual, reverse pattern, B&M transmission cooler
Diff: VN LSD, 3.45 gears
Brakes: WB Statesman 4 wheel discs, PBR calipers
Suspension: Lovells super low springs on front, billet 2" blocks on rear, Koni adjustable shocks all round.
Wheels: Show Wheels Streeters, 18x7 on the front and 20x8.5 on the back
Interior: WB Statesman Deville interior, Autometer speedo, tacho, fuel, water temp and oil pressure gauges, Momo steering wheel, B&M pro ratchet shifter
Up until a few months ago it was my daily driver. Now I've started collecting bits and pieces for a big single turbo conversion
Old 09-07-2011, 09:18 PM
jbsjunk's Avatar
Why are the cool cars down under?
Old 09-07-2011, 10:19 PM
scatillac's Avatar
Very sanitary swap.
I don't know why GM hasn't offered an of your UTE variants over here.
Old 03-25-2012, 10:00 PM
pills85's Avatar
So this is where the car is at at the moment...
Old 03-26-2012, 02:00 AM
Irish350's Avatar
lol exactly what i was thinking... if my 82 caballero was as cool as this ute id have kept it. even without the ls1
very very clean.
that new setup looks ungodly; i hope you post vids
Old 03-26-2012, 11:34 AM
gMAG's Avatar
What a beauty!
Old 03-28-2012, 10:52 PM
pills85's Avatar
Here's a rundown of the specs at the moment:
Model: 1975 HJ Holden Kingswood utility
Body Mods: WB Statesman Deville front, rear bumper shortened, all bolt holes removed, bare metal respray, tonneau hooks removed, pushstud tonneau, WB taillights, metalized window tint
Engine Type: GM Performace Parts LSX 376 crate motor
Engine Mods: LSX Iron Block, LS3 heads, Forged pistons, ARP rod bolts, Canton sheetmetal sump, remote oil filter, relocated LS2 coilpacks, custom ignition leads
Induction: K+N Pod filter, Borg Warner s400 turbo, 600x300x100mm front mount intercooler, Turbosmart Pro-gate50 50mm external wastegate, Turbosmart 50mm Race Port blow off valve, FAST 102mm throttle body, Shaun’s Custom Alloy sheetmetal intake manifold
Fuel System: Custom alloy 140L fuel cell, Holley billet lift pump, 2x Bosch 044 fuel pumps, custom surge tank, Turbosmart FPR1200 fuel pressure regulator, billet fuel rails, ID1000 injectors, e85 fuel
Cooling: 3 core alloy Aussie Desert Coolers Radiator, twin thermo fans, colder thermostat
Exhaust: Custom turbo manifold and crossover pipe, 4” dump pipe into single 3.5” exhaust, Varex 3.5” muffler
Gearbox: Northmead built T400, full manual reverse pattern, 2800rpm TCE converter, B&M transmission cooler
Diff: Custom 9” housing, Strange iron centre, Detroit Locker True-Trac, 3.7 gears, 31 spline axles
Power: getting tuned soon
Brakes: 330mm front rotors with VE twin piston calipers, VN rear discs and calipers, WB master cylinder
Suspension: Lovells springs (front), billet 2” blocks (rear), Koni adjustable shocks (front and rear)
Wheels/Tyres: Show Wheels Streeters, 18x7 (front), 20x8.5 (rear)
Interior: WB Statesman Deville interior, Autometer speedo, tacho, fuel, water temp and oil pressure gauges, Turbosmart E-Boost street, Momo steering wheel, B&M Pro Ratchet shifter, B&M billet ****, new Carpet, velour headlining
Stereo: Alpine headunit, Pioneer 4” splits
Hopefully makes some decent power and runs some quick times down the quarter
Old 03-28-2012, 11:22 PM
V8Rumble's Avatar
Cool
WOW... Looking at that as a "Yank", that just looks so weird, yet still strangely COOL!! Even though I know that Holden == GM, the side view kind of reminded me of a F*rd Ranchero that we'd see up here! (No offense intended!) And I flat-out LOVE that intake manifold setup you have!!
Very cool man, add me to the list of people who'd love to see a good vid or two...
Quick Reply: Aussie HJ Kingswood single turbo lsx376
