Mass Air Sensor
Mass Air Sensor
I just upgraded to AFR 215 Heads, 102mm fast intake and 102mm fast throttle body. Do I need to upgrade the Mass Air Sensor and if so, what size or do they even make sizes. The stock MAS is 85mm. Almost done with car and ready to roll.
I do know that when you get a tune that 85mm maf will limit your tuner to what he can get out of your set up. you have spent alot in the intake tb and heads why not keep going and get a bigger lid and maf
