check engine light on cat delete help!!!!
01 trans am ls1 full exhuast, long tubes eliminated my cats, have numerous codes now, was told 02 simulators would get rid of the cat codes, is this true???
Internet Mechanic
2nd they do nothing to the computer to remove anything. They are supposed to give back a false signal of what the down stream O2 readings and supposedly will trick the PCM in thinking stuff is ok.
Your better off having them turned off. That will elimiate all your issues.
