1st gear fine,2nd gear fine,3rd gear breaking up
Old 09-08-2011, 10:06 AM
sjones99's Avatar
Default 1st gear fine,2nd gear fine,3rd gear breaking up
Motor is 441 lsx and car will go to 7000rpm in 1st and 2nd but when you shift to 3rd and it gets to 6000rpm it starts to break up.I`m confused! Car was fine on dyno but has new problem as of last week.
Engine specs:
13:1 comp
lsx/ls7 heads with comp 921`s
251/266 110 lsa 623 lift
TH400
BS3
5000 stall
Old 09-08-2011, 11:01 AM
good2go's Avatar
It's breaking up in the higher gear because you are loading the engine more, it's in a different part of the map. Try scanning the engine while in third, and check the A/F with a wideband if possible.
Old 09-08-2011, 07:22 PM
S10xGN's Avatar
That, or you're running out of fuel (pump)...
Old 09-09-2011, 07:14 AM
sjones99's Avatar
Doubt the fuel..have a lonnies twin pump and 85lb injectors..on dyno they were only at 30%
Old 09-12-2011, 09:18 PM
moge11's Avatar
not a big enough line?? filter not flowing enough???
Old 09-13-2011, 12:17 AM
racerfox's Avatar
i say its in the tune
Old 09-13-2011, 01:33 AM
nmass399's Avatar
What kind of fuel are you running, mine starts detonating after the shift to third and some to 4th when running 93.
Old 09-13-2011, 07:29 AM
sjones99's Avatar
Runnin vp110
Old 09-13-2011, 04:26 PM
nmass399's Avatar
You could look at fuel pressure during a run, since its breaking up on you the wideband will be useless. I am not really sure what to tell you man, hope you figure it out. I still got to test mine out again to see if its fixed. I put vp 109 in mine and it was better but it seemed like it still had that hesitation after shifting.
Old 09-13-2011, 04:55 PM
sjones99's Avatar
figured out the issue...car had tr6`s gapped at 40...switched to 7`s gapped and 35...runs perfect!
Old 09-13-2011, 05:04 PM
nmass399's Avatar
Good man, i thought about that at first for mine but just pushed that idea to the side. I got mine gapped at 60 on tr55's lol. Probably one issue for me.
Quick Reply: 1st gear fine,2nd gear fine,3rd gear breaking up
