1995 z28
1995 z28
Year: 1995
Make: Chevrolet
Model: Camaro
Price: $5000
Mileage: 64000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
1995 Z28 Camaro Red w/black top and T-Tops. Paint is in good condition, Stock LT1, less than 65K on car. Burns no oil, no leaks, AC needs recharged but works, manual windows, mirrors. T-Tops dont leak. Brakes in good condition. Exhaust in good shape. Gray leather interior, no rips or tears 4L60E w/3200 converter and 4.11 gears Stock motor,throttle body, and cam. Heads untouched.
Mods: Mallory 685 box wired up and using the 2 step, rev limiter, high speed retard and window switch to control the nitrous. Pacesetter coated long tubes . Single bullet muffler,( cat deleted)
EGR, Air pump, cruise, and traction control deleted. Installed Line lock Taylor, OVC wires with heat shields on boots, BMR subframe connectors, double adjustable Lower Control Arms, HAL 12 ways on back, UMI torque arm re-located off trans (with DS loop) Prostars on all fours with MT front runners and ET Streets on back, New nose and VFN pin on 4inch cowl hood. NX kit mounted and plumbed thru relays and ready to go. DynoJet WB installed New Bosch III 28# injectors installed less than 300 miles ago. Car goes 13.20s consistently off the bottle. Would be very competitive in the street class at you local strip.
Will run low 12s on 100 shot. Still gets 19mpg on the hwy.
