will i get piston slap?
Old 09-08-2011, 10:41 PM
ItalianZ28Stallion's Avatar
Default will i get piston slap?
im going to be putting in a dome style piston in my ls1 and put on a set of 243 heads with a .71 head felpro gasket. if i need to post any other mods please let me know.
Old 09-09-2011, 12:30 AM
01 WS6 6.0's Avatar
Best way to find out is to check your ptv clearance with some clay. what are the specs on the cam and pistons?
Old 09-09-2011, 02:33 AM
ZeeOSix's Avatar
The term "piston slap" has to do with piston skirt height and piston to cylinder clearance; and the "slapping" of the piston's skit on the cylinder wall which makes the audible noise. Not sure what the OP is after here.
Old 09-09-2011, 03:09 AM
01 WS6 6.0's Avatar
Yeah I my fault I thought he was refering to a ptv situation, piston slap would be as you described.
Old 09-09-2011, 04:02 AM
PREDATOR-Z's Avatar
I think OP should step away from "old school" practices and research more on LS platforms.
Why? Because unless this is a very specific application, we do not practice "dome pistons" for street and thick gaskets. They surely contradict each other and are more prone to detonation.
