Spec Stage 3+ ??
Old 09-09-2011, 08:16 PM
ssheets's Avatar
Default Spec Stage 3+ ??
Getting the tranny fixed and I found a tuner. Since the trans is out I was thinking about the clutch and when I told my tuner what mods I had he recommended the Spec Stage 3+. I know it's a good clutch, but can I go too far with it?
My car is an 02 SS with an LS1 with custom heads with 2.02" intakes 59cc chambers ported etc., a Futral F14 cam pro gold dual springs, long tubes and straight pipes.
I wish I had money for an aluminum flywheel
Old 09-09-2011, 08:35 PM
wicked z28's Avatar
You should be fine great clutch
Old 09-10-2011, 10:41 AM
CALL911's Avatar
The clutch is rated at 750 RWTQ. I think even a very strong heads and cam is still going to leave you quite aways away from being close to that power level.
It's a great clutch to have and drive. I have it in my boosted LT1 car in my sig and love it.
Old 09-12-2011, 02:44 PM
SPEC-01's Avatar
Our 3+ will provide plenty of capacity and great drivability too. It would be an awesome option for you. Let me know if you have any further questions and I will be happy to assist you. Thanks,
Old 09-12-2011, 03:27 PM
karpetcm's Avatar
How much tq can a 2+ handle?
Old 09-14-2011, 02:28 PM
SPEC-01's Avatar
Stage 2+ is rated to over 780lb.-ft at the crank for the LS1 based kit.
Old 09-14-2011, 04:39 PM
karpetcm's Avatar
Does the stage 2+ have chatter, in some pics ive seen looks like its not a true puck design a full disc with ceramic or kevlar every couple of inches but not sure.
Old 09-15-2011, 09:18 AM
SPEC-01's Avatar
The 2+ uses a carbon-graphite semi-metallic puck on one side and a segmented kevlar on the other. This is not technically full-faced but the engagement will be very smooth, like what you would expect from a full-faced disc. I run a 2+ in my daily (and have used the 2+ in my last 4 cars). It is one of my favorite kits that we build.
Quick Reply: Spec Stage 3+ ??
