Gen 5 Camaro Internal Engine Tech - Livernois Motorsports September LS3 & L99 Camaro Camshaft Install Package Specials
LivernoisMotorsports
09-10-2011, 08:39 AM
For the month of September, we are offering a vehicle install package for our LS3 & L99 camshaft install packages.
The LS3 package sells for $3,799.00 installed and tuned and can be found here (http://www.livernoismotorsports.com/products/2010%252d11-Camaro-LS3-Stage-2C-Camshaft-Package-Installed-%252d-September-Special.html) and includes:
Livernois Motorsports Stage 2C Camshaft
Livernois Motorsports Dual Valve Spring Package
(Livernois Motorsports Dual Valve Springs, Titanium Retainers, Valve Spring Locators, Locks, & Valve Seals)
Hardened Pushrods
Stainless Longtube Headers
Stainless 3" Catted Connection Pipe
Wideband 02 Bung
Cold Air Intake
NGK TR6 Spark Plugs
GM 3-Bolt Cam Sprocket
ARP Cam Bolts
GM Exhaust Gaskets
Fluids & Synthetic Oil Change w/ Filter
Professional Installation
Livernois Motorsports Dyno Tune
http://www.livernoismotorsports.com/product_images/l/697/CAMAROLS3PP1OX__44764_zoom.jpg
The L99 package sells for $4,599.00 installed and tuned and can be found here (http://www.livernoismotorsports.com/products/2010%252d11-Camaro-L99-Stage-2C-DOD%7B47%7DAFM-Delete-Camshaft-Package-Installed-%252d-September-Special.html) and includes:
Livernois Motorsports Stage 2C L92 Camshaft
Livernois Motorsports Dual Valve Spring Package (Livernois Motorsports Dual Valve Springs, Titanium Retainers, Valve Spring Locators, Locks, & Valve Seals)
ARP Head Bolts
MLS Head Gaskets
Hardened Pushrods
Stainless 1 7/8" Longtube Headers
Stainless Catted Connection Pipe
Wideband 02 Bung
Cold Air Intake
NGK TR6 Spark Plugs
GMPP LS7 Lifters
GMPP LS2 Lifter guide kit
GMPP LS2 Valley Cover
GMPP Valve Cover Breather Block-Off
GMPP LS7 Camshaft Sprocket
GMPP Timing Chain Dampner
GMPP PCV Hose for Non-DOD applications
GMPP MLS Header Gaskets
ARP Camshaft Retainer plate bolts
ARP Timing Chain Bolts
LS2 Front Cover
http://www.livernoismotorsports.com/product_images/m/685/CAMAROL99PP1OX__04309_zoom.jpg
We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules.
We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that you car will make it to our location and back to you safely, and with much more power than it arrived with!
Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer.
Call or PM today to schedule your appoint or ask any questions you may have!
Thank you
Regards,
Rick LeBlanc
