Road Racing - Need new shocks and springs on car that occasioanlly sees track time
treyZ28
09-10-2011, 12:28 PM
2000 Z28. It sees track time every now and again.
I don't mind harshness, but I'd like to retain as much factory ride height as possible. Also, I don't know what happens to factory geometry when it's lowered.
Since it's an old car that sees maybe 2 track days a year, budget is the word.
JD_AMG
09-11-2011, 05:14 PM
Why is this, do you want to keep ground clearance?
Either way you can stick with your stock springs as long as they are not sagging.
Do a search here and in the suspension section there are topics like this all the time. You will want a sport shock, not a drag shock (so stay away from QA1s, Afco, Strange) and look into Bilstiens, KYB AGX, and Konis. Depending on budget you can always get a custom valved shock as well.
treyZ28
09-12-2011, 08:24 AM
I'm more worried about messing up suspension geometry and having a worse handling lower car.
Ground clearance is nice, but it's not a deal breaker. I don't want to slam it, but a mild drop wont have me scraping anything.
B Stead
09-12-2011, 07:35 PM
KW has a coilover kit for the 2000 Camaro.
They are height adjustable only by spring pre-load and that means that the suspension gets stiffer when raised and softer when lowered.
treyZ28
09-12-2011, 10:22 PM
:lol: kind of out of the budget.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
