TReX dyno - 1998 SS - cam only
Old 09-10-2011, 08:32 PM
mshadow's Avatar
Default TReX dyno - 1998 SS - cam only
420/380
Stock Heads
Dual Valve springs
Katech Rod bolts
LS6 intake
Ported TB
3 inch duals into 4x9 magnaflows
6spd
Stock 10bolt 3.73s
Time to buy a FAST intake
Old 09-10-2011, 10:12 PM
ds98formula's Avatar
Awesome number do you have the dyno sheet?
Old 09-10-2011, 11:35 PM
LSWONGTO's Avatar
A dyno sheet would rock! Congrats on the good #s btw
Old 09-11-2011, 12:05 AM
Johnnystock's Avatar
Nice results, want to see graph too
Old 09-11-2011, 06:24 AM
mshadow's Avatar
Yea I gotta get a copy scanned
Old 09-11-2011, 08:06 AM
mshadow's Avatar
Smoothing is turned off on this run
Let me try and dig up another sheet im pretty sure leaning it out a bit did 421 on one pass
Old 09-11-2011, 11:48 AM
SSickLS1SS's Avatar
damn nice numbers for cam only
Old 09-11-2011, 11:55 AM
s346k's Avatar
good numbers. not sure how a dynomite reads vs a dynojet or mustang..?
any before numbers / track times?
Old 09-11-2011, 03:15 PM
How does it drive on the streets with the 3:73? ..gotta love the Trex!!
Old 09-11-2011, 03:21 PM
mshadow's Avatar
It usually reads lower then a dyno jet someone else local with a H/C TA dynoed 460rwhp and trapped 123.
No track times working on weight reduction on the car now and waiting for winter to swap in a TH350/9inch also need to finish up suspension over winter.
Just trying to get some baseline numbers
1st gear at slow speeds gets some bucking besides that its fine you really need 4.10 or higher gears to clean that up.
However every other gear is fine even low rpm in 5th and 6th.
Old 09-11-2011, 03:40 PM
not too bad!!^^
