dboone2172
09-10-2011, 09:24 PM
I have a 2000 SS Camaro that I put a silver gauge overlay on. It went on ok but the oil pressure gauge doesn't work right.
When you start the car up it is ok, it works like it should, but when you turn the car off the gauge does not retract to zero.
Now if you let the car sit, and then turn the key to run it will reset to zero and then you start the car and it works.
