Broken Pushrod
Old 09-10-2011, 10:52 PM
stlracing289's Avatar
Exclamation Broken Pushrod
Hey I have a 2000 z28 and recently had a misfire on cylinder 2. So thanks to a buddy we took off the header cover and found out it had after market rocker arms but still had stock springs and pushrods. We found that the pushrod was bent and broken... However we have no clue why this happened. It has a stock cam and when we put a new push rod it worked normally. Any ideas of why it broke?
Attached Thumbnails Broken Pushrod-2011-09-10_18-55-31_100.jpg   Broken Pushrod-2011-09-10_17-56-56_964.jpg
Old 09-11-2011, 12:15 AM
usafws6's Avatar
They bend and break from over rev conditions. So someone probably missed a shift. Change all the pushrods now before another one breaks.
Old 09-11-2011, 07:21 AM
777's Avatar
Plus those are probably 1.8 rockers arms which are putting more stress on the valvetrain. You'd also need better valvesprings with those rocker arms (if they are different than 1.7's)
Old 11-16-2011, 08:36 PM
marthastewart's Avatar
I have the same problem with my 99Z. Did you pull the head or just replace the pushrod and throw it back together and hope for the best? I am thinking of pulling the head just because I am alread this far into it. really dont want to though.
Old 11-17-2011, 06:49 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Over revving and lack of spring control. Get some stock rockers back on as well.
Old 11-17-2011, 05:49 PM
dyls1's Avatar
2 month old thread, any updates OP? And I agree with BlackScreaminMachine
Old 11-17-2011, 06:14 PM
Im going with plan B. Heads and cam! Gunna get PRC 5.3 cnc with T2 cam from TSP. That should fix er...
Old 11-17-2011, 06:49 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
That should do the trick!
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 11-23-2011, 10:38 PM
Sooo Pretty!
Old 11-24-2011, 07:15 PM
Internet Mechanic
I once had a valve that looked like that....
Old 11-25-2011, 10:48 PM
Well we ended up replacing all the pushrods and replacing the rocker arms back to stock ones and no problems since!
Old 11-26-2011, 11:26 AM
camaroboy14's Avatar
That's great !!! Good luck with the H/C set up too man
Old 11-26-2011, 11:30 PM
doublea87's Avatar
well when we replaced the rockers and pushrods we also found another 4 maybe? pushrods bent and 1 more broken. good thing we swapped them!
Quick Reply: Broken Pushrod
