Stereo & Electronics - Radio off, still a noise comign through speakers.
KJZ28
09-10-2011, 11:49 PM
So when I turn my radio off, there is still a sound, like interference, that comes through on the speakers and gets louder with more engine RPM, any ideas? This is quite annoying when I just want peace and quite on my commute.
Stock Monsoon HU w/ LED w/ resistor swap and JL door speakers installed the way recommended on this site.
BandDirector Blk98ZM6
09-14-2011, 04:10 PM
Still the stock system?
I've got an aftermarket system in my daily driver that did something similar recently and it turned out to be a lose ground on the back of my HU...if you've got an aftermarket system, I'd start checking all the grounds.
lemons12
09-14-2011, 04:17 PM
Buddies does it with his aftermarket... Annoying and funny because it goes with rpms.
KJZ28
09-14-2011, 08:47 PM
It is the stock Monsoon head unit. But recently I did the LED swap w/ resistors. And the stock speakers went in the doors so I put in JL units.
09-15-2011, 08:09 PM
Did you replace the stock Monsoon speakers with standard 4 Ohm JL's WITHOUT an aftermarket amp to power them?
KJZ28
09-15-2011, 11:12 PM
yea, they are C2- 650x 4ohm, 60 watts of continuous power, and 15-100 watts per channel
dragonrage
09-16-2011, 07:25 AM
Bad grounds
Bad alternator
Bad head unit
Wiring short/problem somewhere
etc...
KJZ28
09-16-2011, 02:22 PM
Bad grounds
Bad alternator
Bad head unit
etc...
ahhhhhhhhhhhh :eek2:
KJZ28
09-16-2011, 08:35 PM
For some reason after my mechanic replaced the broken windshield wiper motor, and the other motor involved with the wipers, the sound went away!!!!
Thanks guys for your help...AGAIN!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
