Would it even spool?
If I did put my s475 with a 1.32ar and 96mm turbine wheel in the rear of my GTO, would it even spool? Assuming a single 3" or dual 2 1/4" pipes to the tubine with exhaust wrapping and a blanket on the turbo? I really want to put it in front, but I'm not sure I can get a proper downpipe on it. If I did do a rear mount, I would try it without a quick spool valve first, since that thing is expensive as heck.
Concerning front mount. If I notched the frame and boxed it in, would the cars structure be maintained good enough?
410 correct? T4 PT88 .96 AR. Even then it would take a while longer than front mounted. ST80 Maybe a good choice for rear mount. Just know that unless you want a good bit of delay/lag you won't have near the rpm powerband you have now judging by the combo you have. Your on YB no?
