2002 trans am jumps to 4k rpms at on start up
Old 09-11-2011, 12:11 PM
nasty00vert's Avatar
Default 2002 trans am jumps to 4k rpms at on start up
I just put a set of lifters in a 2002 trans am that has patrior performace stage II heads comp cam 230/232 .591/594 lift 114 lsa custom tuning by futral motorsports and a ported throttle body.. the car ran fine other than the lifter tap when i came in but now every time you start the car it jumps to the rev limiter and hangs there i check for vacuum leaks none were found and everything is pluged back up the way it was.... i really dont know where to look any ideas? thanks..
Old 09-11-2011, 12:28 PM
ULTIMATEORANGESS's Avatar
id bring it back to your tuner for adjustments.
Old 09-11-2011, 12:51 PM
see thats the only thing i could think of but could that really make it idle that high? also where it got tuned was states away is there a way to get a mail tune?
Old 09-11-2011, 07:56 PM
usafws6's Avatar
Have you checked to see if the tb cable is hung open?
Old 09-11-2011, 08:20 PM
71novaguy's Avatar
Tps??
