8.8 conversion axles !
Old 09-11-2011, 12:18 PM
Pewter53's Avatar
Default 8.8 conversion axles !
does anyone know what axles to get for a 8.8 fbody conversion ? I broke one yesterday at the track and need one.
Old 09-11-2011, 01:22 PM
Pocket's Avatar
Lots of variables because no two 8.8 conversions are the same
What did you do for the conversion?
Old 09-11-2011, 03:31 PM
Pewter53's Avatar
bought it off here its just an 8.8 center with fbody tubes.axle is 31 spline but has ford threads want to go back to fbody 12mm studs.
Old 09-11-2011, 03:34 PM
Maroboy's Avatar
Pewter53. Can u post some pics of the rear end pls??
Thanks
Old 09-11-2011, 03:55 PM
Pewter53's Avatar
ill take some pics when i get home.
Old 09-13-2011, 01:44 AM
Maroboy's Avatar
Thanks
Old 09-13-2011, 11:02 AM
Pewter53's Avatar
havent had a chance to get to it but i will this afternoon sorry.
Old 09-14-2011, 11:53 PM
dutinsss's Avatar
are you using f-body or mustang brakes?
Old 09-15-2011, 07:02 PM
Pewter53's Avatar
Fbody its a 8.8 center with stock fbody axle tubes.
Old 09-15-2011, 09:21 PM
dutinsss's Avatar
if you call moser or strange and tell them you have stock f-body length axles with f-body ends on the wheel side with 8.8 ends on the diff. side(if it makes a difference) they should be able to make you whatever you need.
Old 09-15-2011, 11:30 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ They're probably still going to ask you to measure everything. I'm sure they wouldn't want to just guess on making a set of axles and then ship them to you with the idea that they may work.
Old 09-15-2011, 11:41 PM
dutinsss's Avatar
true. you could always call and ask the guy you bought the rear from. or use your good axle for reference on any questions the manufactorer has.
Old 09-17-2011, 03:12 PM
Pewter53's Avatar
Well i got everything apart and its the spider gear that broke 3 teeth off
Quick Reply: 8.8 conversion axles !
