wiring harness
Old 09-12-2011, 04:07 AM
wayne33's Avatar
Default wiring harness
has anyone here used schwanke engines wiring harness?
If not what do you think? what is the purpose of not having o2 sensors and knock sensors?
HERE THE AD
24X Wiring Harness and ECM
Price: $515.00
Custom stand alone Harness Designed for tight engine bay applications, open loop only wiring harness,allows easy installation, 4 fuse panel, ALDL connector, Fuel pump relay, 3 wire hook up with 1 fuel pump wire and tack, 3 injector harness leads avaliable (Specify Injector Plug), This kit is designed to up-fit any GM LS series engine with 24x crank front or rear cam sensor. Also includes PCM with a base tune with other tuning options available.(Please Specify in order)
NOTE: Harness does not include provisions for O2 sensors or Knock sensors.
Old 09-12-2011, 07:15 AM
46Coupe's Avatar
HERE THE AD
Price: $515.00
I have not but I am now a huge fan of one of our sponsors here www.PSIconversion.com.
Talk to Jon, and tell him you're an LS1tech member and get some free shipping. PSI will call walk you through any question you may have, help you trouble shoot, they even called me back on a Sunday morning.
My 2006 L59 drive by wire runs like a top and the quality of the harness is fantastic.
Old 09-12-2011, 07:57 AM
LS1Tech Sponsor
psiconversion's Avatar
o2 and knock sensors are going to allow your engine to run in closed loop, how it was designed to run, to get better fuel economy and overall driveability.
What is your engine/transmission application? Our drive by cable harnesses are $499. Give us a call if you would like some specifics at 732-691-6531.
46, Thanks for the compliment. Glad everything is working well.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 09-12-2011, 01:03 PM
wayne33's Avatar
ls1 with ls6 top end/ t56..
@psiconversion does you harness come with a fuse box, relays?
Quick Reply: wiring harness
