on board monitor test $07 and $0C
I don't see monitor MID $07...
MID $0C is catalyst efficiency.
MID $0C TID $70 is catalyst efficiency bank 2.
MID $0C TID $60 is catalyst efficiency bank 1.
[ MID = monitor id; TID = test id; each monitor has several tests ]
No start, just spark
Mine throws that code too but won't start on a 98 chevy silverado 5.7 replaced fuel pump, regulator, plenum, spark plugs, wires, spider , sensors, still won't start . turns over, back fires when using starting fluid, any ideas?? I don't know what else to do
Hopefully someone will chime in. You replied to a ten-year old thread.
Also check that the exhaust is not clogged (i.e. catalysts causing blockage).
The following 2 users liked this post by joecar:
ChopperDoc (11-24-2021), G Atsma (11-16-2021)
