Why no gains after head install?
Recently installed some PRC stage 1 ls6 heads that were milled to 62cc and used a .045 head gasket. When I went to the track this last weekend my car ran the same MPH as when it was cam only. The weather conditions were pretty much the same as before. Since running cam only car received a k-member and I went back to 3.23 gears from 3.73? I was hoping the car would run at least 116mph. I do all of my own tuning and feel the tune is pretty good. I can post it up if someone wants to look.
EDIT: Final Dyno pull attached.
No I had the 853s. No dyno tune just a street tune. As far as spark goes I am not sure if I am getting false knock or real knock. But don't see anymore than 2 deg pulled a WOT, that puts me at about 24 deg total. Is that too high for 11:2 CR with 91 octane?
Of course something is wrong............why use the same cam with a new set of heads? They have to be matched together if you want to get that ~40 RWHP out of them thats still on the table. Heads that breath more need a cam to allow it......
You obviously gained a little through simply having better flowing heads, lost a LITTLE bit with the gear change. But you should have seen a big difference....with a new cam.
OP, something is wrong. Your 60 should be better, you ET should be better, and your mph should be better.
