5.3 rattle
Old 09-12-2011, 05:52 PM
Lahoe5.3's Avatar
Default 5.3 rattle
Hey guys im new to this forum =D got reffered to this website thanks to some friends from Tahoeyukonforum the reason im here is to find out some info on my 5.3. I have a slight knock/rattle which i believe is being produced by a lifter if im wrong please tell me. Now i believe this problem started not long ago cause it would only do it at cold start, but as soon as it would get to running temperature it would go away. But now it seemes like the noise is there to stay. I opened up my oil pan to check if i spun a bearing but everything seems to be ok. Also my oil pressure gauge since i removed it has been acting up and not reading the correct oil pressure.
Old 09-12-2011, 07:17 PM
SOMbitch's Avatar
Post a clip of your noise but I have a sometimes noisy LM7 219K going strong so more than likely ok.....
Old 09-12-2011, 07:34 PM
kinglt-1's Avatar
the 5.3 in my silverado is the same way.
Old 09-12-2011, 08:49 PM
O2Form's Avatar
prolly piston noise.....very common
Old 09-13-2011, 08:50 AM
Lahoe5.3's Avatar
thanks for the reply guys and a friend of mine also told me it might be piston slap but yesterday i opened up my valve covers and the one on the driver side has signs of the rockers hitting it ''/ could it maybe be a pushrod??
Old 09-13-2011, 09:07 AM
O2Form's Avatar
wow thats odd, what part of the rocker is hitting? Are the rocker support bolts tight?
Old 09-13-2011, 09:30 AM
Lahoe5.3's Avatar
yes the rocker supports are tight and i know it really is wierd ill post a pic of it
Old 09-13-2011, 10:17 AM
O2Form's Avatar
Check for cracked or broken springs.
