Those Who Run An Open Cutout
Do you hear any vibrations? It seems I have a bad one in the rear at low rpms', but it stops when I give the car some more throttle. It is annoying slowly accelerating.
I have a rumble as well and a slight vibration inside on lower rpm's.
I see you have a 98', more than likely things are starting to loosen up inside, mainly console or dash stuff. The older the car gets, it seems stuff starts to rattle more and more.
Mine is at the end of the I pipe, it sounds like it is around the muffler though, maybe like a heat shield I have heard or something? I got up underneath there, and couldn't find anything loose though
