Carbureted LSX forum - steam hole block off
View Full Version : steam hole block off
70shortwide
09-14-2011, 12:54 PM
i know ive seen this covered on here before but cant find it. i need to know what to use to block off the steam holes in the heads. thanks.
tommy396
09-14-2011, 01:24 PM
http://s41657.storefront-solutions.c...l.aspx?ID=3289 Kneivel sent me this link a while back & I bought them & put em on mine, they work great!
70shortwide
09-14-2011, 01:27 PM
the link isnt working.
Prorac1
09-14-2011, 01:36 PM
12602540-blocks for rear steam ports
12551933-seals 2 new seals for blocks.
70shortwide
09-14-2011, 01:41 PM
will that plug the front and rear?
Prorac1
09-14-2011, 02:20 PM
Yes, its the same part number for all 4 ports IIRC.
70shortwide
09-14-2011, 02:34 PM
cool thanks guys.
ATwelveSec02Z28
09-14-2011, 06:18 PM
You do know it is a BAD IDEA to block all 4 steam ports.... Hell I went through the trouble of USING all 4.
70shortwide
09-15-2011, 07:17 AM
well it seems like about half the guys on here have them blocked and the other half dont. from what i understand from reading all the info is that the reason they are on there is the radiator wasnt the highest point in the cars so these kept air pockets out of the heads. if im wrong let me know. i deffinitely dont wanna melt it down because of some stupid steam holes.
ATwelveSec02Z28
09-15-2011, 07:26 AM
Steam vents are there because the outlet of the cooling system is below any part of the head. Unlike a conventional SBC where the water outlet is in the intake manifold that connects both heads the LS engines will trap air. Air will cause hotter spots in the combustion chambers and promote detonation.
There is a reason folks like Kurt Urban sell 4 port steam vents like this...
http://www.kurturbanperformance.com/ls-water-vapor-system.html
70shortwide
09-15-2011, 08:21 AM
http://s41657.storefront-solutions.com/detail.aspx?ID=3289
i might use these then and just plumb it myself with hard line
Pop N Wood
09-15-2011, 11:58 AM
You might want to do a little more reading on here. This subject comes up constantly. There are a fairly significant number of guys on here who have run for years with all four vents closed off. Once you get the air out the vents are no longer needed. You just need to make sure you get the air out when you do the initial fill. Plumbing in the vents is just cheap insurance against future mishaps.
I'm sure people will sell anything other people are willing to pay money for. The trick is figuring out what is needed and what isn't.
Your money, your car, your decision.
GTMLS3
09-15-2011, 12:02 PM
So did I, why take a chance
70shortwide
09-15-2011, 01:12 PM
well the ones i found will allow you to plumb or cap and there cheaper than stock so i will just buy them and decide later.
Prorac1
09-17-2011, 12:13 PM
what did you find?
70shortwide
09-17-2011, 12:46 PM
i posted the link a few posts up
Prorac1
09-17-2011, 01:04 PM
Sorry, lol. Im so poor I cant afford to pay attention. Thanks, Eric L
LSwonderfull
09-20-2011, 08:43 PM
I run all 4 on my LS motors merging the rears with the fronts like pre LS6 intakes. It cant hurt to purge steam pockets for max timing tuning.
