1999 Formula with lots of goodies
Year: 1999
Make: Pontiac
Model: Firebird
Price: $6000
Mileage: 113000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
it also has a built 8.8 hybrid rearend. The 10 bolt tubes(off of a 02 Trans Am) were professionally milled down to the perfect diameter so they fit snug right into the 8.8 housing, after that it was took to a professional welding shop where it was welded. the 8.8 tubes were even extra welded with the nickel rod(cuz the housing is cast steel) so this way you will never have to worry about twisting a tube. the 10 bolt tubes have 4 big plug welds besides the weld around the tube for maximum strength as well. The Ford axles have alittle bit bigger of a lip i guess you could call it where the c-clip connects so putting your GM axles in the 8.8 posi make a little bit of slop from side to side, i had button machined that fits on the end of the GM axle that will take up the slop(so you dont have to worry about kicking a c clip!) the GM axles came out of a 2002 Trans Am with 40k on them, so they are in excellent shape. it also has the maximum motorsports torque arm (made for the 8.8 rearend) and a Trick flow Girdle.
The paint is in good shape for its age and mileage. the car is located in MI $6000
http://i237.photobucket.com/albums/f...-19-06_654.jpg
http://youtu.be/PRbd1ztwO_A
