5.3 n fox body ????? i need help
Old 09-14-2011, 06:40 PM
SuperSlowCamaro's Avatar
Default 5.3 n fox body ????? i need help
i just finish building my 5.3 for my 80 malibu but i wanna throw it in my 90 fox body.
i now ima need the adapters n all that. but here r my questions.
can i use the stock k member or i need to get a aje?
what oil pan do i need to use?
can someone help me
please put pics
Old 09-14-2011, 07:47 PM
Mustang605's Avatar
you need the F-body, or Cadillac cts-v oil pan...the truck pan will work but hang low..they make motor mounts & headers for the stock k-member...or you can use a 4.6 mustang k-member..you can also use 351 ford headers & cut the flanges off...I've even heard of f-body headers working with a little modifications...but they make multiple headers for the swap..you'll want an aje cross member..cost around $150
Mustang605's Avatar
use the search button though..you can find alot of information
Old 09-15-2011, 01:52 AM
ok kool. yeah i wanna do that but the end of christmas. u help me out alot i really appriciate it bro.
i look at the aje crossmember but i only saw a kit that cost 799. were can i find a aje for that price
Old 09-15-2011, 01:56 AM
what did u use for your swap
Old 09-15-2011, 05:09 AM
Jasons50's Avatar
Look on latemodelrestoration.com I'm thinking they offer a cheaper k member with chevy mounts. You can buy it with or without a-arms. Goodluck on your chevystang
Old 09-15-2011, 07:41 AM
boostnut's Avatar
you can buy the AJE parts directly from AJE, just call them.
Old 09-20-2011, 08:51 PM
bigchief52780's Avatar
buy from summit racing. they are cheaper than ordering it direct.
Old 09-21-2011, 06:36 AM
boostnut's Avatar
Not sure about that, look carefully at what you're getting. When I bought mine (about 10 months ago) summit & jegs sold the bare k-member and the engine mounts had to be purchased separately. I bought mine with the mounts from AJE for a few bucks less than the combined price thru jegs. Aside from that, the guys at AJE were quick to answer my questions and address some concerns over the phone after the sale. If you're gonna go AJE, buy direct.
Old 09-21-2011, 07:32 AM
street_trash's Avatar
When you get the k member, make sure to get the spring perches as well. If you plan on keeping stock suspension with stock control arms. You will also have to lengthen your steering shaft about a inch or so The swap is actually fairly easy as far as I have made it. Here are a few pics.
Also, the hookers super comp equal length Shorties for the f body will work for headers if you cut the flange off.
Old 09-21-2011, 09:50 AM
dmracing's Avatar
You have any pics of the super comp on the drivers side
street trash
Old 09-21-2011, 12:21 PM
boostnut's Avatar
street trash
x2, lets see some pics of those headers!
Old 09-25-2011, 01:34 PM
V-seriesTech's Avatar
What are you doing for the steering shaft?
Old 09-25-2011, 02:44 PM
9389coupe's Avatar
On the steering shafts, the short piece coming through the firewall from the column will move in and out with some force. It is designed to telescope a good bit. I have moved mine out about an inch on one car and had to shorten 1 about 3/4" on another.
Old 09-25-2011, 04:57 PM
Baby jesus.
Awesome news,..have not gone inside the car yet to look when I did swap but you can bet your *** tomorrow morning I will be checking this out at work.
THANKS!!!
Old 09-26-2011, 12:11 PM
9389coupe's Avatar
You have to pull it out or push it in from under the hood by the firewall. I am referring to the short piece with the bolt hole in it that you slide the steering shaft into. It is way harder to pull it out than pushing it in, but it does move.
Old 09-29-2011, 11:18 PM
gols1go's Avatar
Who makes motor mounts & headers for the stock k-member
Old 09-30-2011, 07:22 AM
boostnut's Avatar
http://www.brphotrods.com/mm5/mercha...ory_Code=CNV19
Old 10-01-2011, 12:10 AM
darren roar's Avatar
i would like to do a similar swap and retain the stock 5sp tranny, the tranny isnt a t5 its out of a turbo coupe what adapters would i need
Old 10-01-2011, 02:29 PM
lxwithlaundry's Avatar
I made my own engine mounts using the stock 5.3 mounts and made a tranny crossmember.. all for fitting the engine and tranny with stock k-member.. was really easy and I'm very happy with how it turned out.. and my stock truck oil pan hangs about 2" below the stock k-member.. if you want to stay on a tight budget like me it can be done...
Quick Reply: 5.3 n fox body ????? i need help
