LS6 heads on 98 engine...
Old 09-14-2011, 08:17 PM
JB_97ws6TA's Avatar
Default LS6 heads on 98 engine...
What do you have to swap to put LS6 heads on an early LS1, I know the valve covers are different so I am assuming that the valve covers, and coil brackets will need to be changed to the centerbolt version. The PCV is different as well as far as I know so what is the easiest most cost effective way to get a set of heads on this thing? I would like to pick up a set of PRC 2.5 LS6 heads but if I have to change a bunch of stuff to make them work it might make more sense to just have the 241 heads ported...I don't know...
Old 09-14-2011, 09:31 PM
ggino85's Avatar
im in the process of doing this swap on a 98 rite now....... and you pretty much have it. i dont think there is anything else other than what you mentioned. if you do the ls6 intake then you need to mess with a couple other things....egr, coolant crossover(i guess you need to bend it?). thats all i can think of off the top of my head.
Old 09-14-2011, 09:52 PM
JB_97ws6TA's Avatar
I will have to keep the ls1 intake because of the egr and lack there of on the ls6 for emissions reasons. I will keep my eye out for some 99 and up valve covers I guess and if I can get some for a good price I will go with that. It seems that people are awfully proud of them though. Thanks for the reply!
Old 09-15-2011, 09:40 AM
ggino85's Avatar
i just picked up a set for 75$ are ebay, you'll be able to find some for a decent price you just have to hunt around a bit. im in cali also and i still have the ls1 intake but i will be switching over to the ls6 as soon as i pass smog. after that im going to pick up an ls6 and run it for two years until i have to smog again......if by that time i dont find a ''cool'' smog guy.
Old 09-15-2011, 03:24 PM
1sicss's Avatar
SLP does make a LS6 intake with all egr provisions that is what I run I my 98 camaro Z28. Though it is a bit pricey I think like $600.00 bones.
Old 09-15-2011, 03:37 PM
mike171562's Avatar
You will need the coil pack brackets as well, the 98's bolt onto the valve covers.
Old 09-15-2011, 04:06 PM
'02 WS6's Avatar
You must have a stingy inspection man there, you're about the only person I know modding fbodies in TX that cares to be emissions compliant.
Old 09-16-2011, 06:14 AM
MonmouthCtyLS7's Avatar
Was thinking the same thing
Old 09-16-2011, 06:24 AM
82cetuner's Avatar
yup im removing all emissions on my ride LOL and no matter what state im in I can always register it with whatever state I list as home of record
Old 09-16-2011, 07:07 AM
quiet_storm98's Avatar
Slp does make a ls6 intake with the egr provisions, I had one on my 98 when I had it. By the way I have some center bolt valve covers I'm trying to get rid of as well, if interested pm me
Old 09-17-2011, 08:05 AM
89 formula350's Avatar
you got it.. coil brackets, Valve covers and just some hose to redue the pcv system slightly. why not go with a fast intake for that price?
