Cam to big for springs?
I just had a spring break on my setup.
I have L92 heads with the PAC 1518 springs. I bought these heads used which owner stated they had about 1k miles on them (they were clean and in good shape). L76 engine.
I installed them and a cam of the size of 231/236 .641"/615" 112lsa, and engine ran ok for almost 1 hour of total run time, and then I got a noise and found a broken spring.
Is that cam to big for these springs. Any idea for cause of failure?
Thanks
Thanks
LS1Tech Premium Sponsor
You need something like the PRC Double .650" spring kit.
http://www.texas-speed.com/p-474-pre...pring-kit.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
we have some stock valves in case you hurt one, give us a call if you need a spare!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
I see the PAC 1518 springs are rated to .650, so I figured I was ok when I bought these heads..... Also, it was an exhaust spring that broke - I see the intake on this cam has more lift than the exhaust...
Thanks Jason. I will likely be calling you guys soon to take you up on that!
