Canadian Members - Anyone running a FAST 102 ?
View Full Version : Anyone running a FAST 102 ?
janaka
09-15-2011, 08:48 AM
I've seen posts about them but wondering if anyone *up here* has run one yet?
I'm thinking of upgrading and would like to hear some opinions and what fuel rail system you used etc.
Any input would be great.
Thanks
Jay
Spd-Kilz
09-15-2011, 09:15 AM
Only a FAST 92 here. I'm running stock rails for the time being, but looking to get something a little different over the winter.
That Datsun must be crazy.
janaka
09-16-2011, 09:11 PM
Ya i'm running a FAST90 now but will have to change my fuel rails from what I understand to accomodate the 102. I can't use the LS2 fuel rails as I don't use the OEM quick connect fitting on my rail due to my different fuel set up.
hmmm
RAMPANT
09-16-2011, 10:02 PM
Orange Juice has one on his 440 LS7.
Orange Juice
09-17-2011, 06:25 AM
What would you like to know, I can't give you any data on HP since I haven't finished tuning with all the little issues that keep popping up. There is a good write up on the site. Didn't really have any problem with mine. We moved the map sensor to the front of the intake which is one of the issues that can be a problem. It cleared the waterpump but we ground some off anyways, I bought new fast billet fuel rails. You will need the larger o rings on the injectors so that they fit. It is tight to install in hindsight if you got a couple of 5mm allen key. I think that is the size and cut them to length then welded a nut to the top of them so that you could use a speed box end on them it would make the job alot easier. Any questions you can send me an email at ybconway@gmail.com
eb02z06
09-21-2011, 08:15 AM
I have a FAST 102 for sale, with the FAST rails and a 90mm TB-$1000.
Orange Juice
09-21-2011, 07:07 PM
The one draw back to the 102 tb is connecting it to a lid. because I went mafless I used a 4 1/2 inch single bump from the 102 to a transition piece that I had made at a muffler shop that necked down to a 4" with a 4" single bump hooking up to a 96mm lid
spiro27
09-26-2011, 04:54 PM
how much for the 102 and rails will it fit a 102 tb on in it let me know pr message me thanks
cutlass_455
09-28-2011, 09:23 PM
Im using a 102 with a 102 NW TB and FAST billet rails and aeromotive regulator. 6L motor made 415rwhp. Never used any other intake on my build. The FAST rails install a little wierd, but if you pay attention they work great.
